Ok i order the razorweld 30 the big ? Is i have a brand new 30 gallon huskey compressor is that gonna be enough for the cutter to run both will be on 110 possible the plasma might go to 220
Also gonna be cutting on 11g. cause i have unlimited supply signs an firepits is all it will be doing
We don’t generally recommend cutting at 110V as the standoff distances required for that voltage make it hard not to drag into the material. We list the RW30 as a 220V cutter despite it being able to switch to 110V.
30 Gal Husky Compressor should be plenty!
Makes since ill use it on 220v and thanks
