Just got an Everlast 60s machine, and was looking at a machine torch accessory. One reason being that I overlooked how short the hand torch cables were. Will the ptm-60 torch work well with this machine/crossfire? Any experiences?
Did you ever get an answer?
I thought mine came with 20’ of cable. ill check but the plasma cutter is 2 feet away on one side the cable runs almost along the floor up the opposite side and back across the crossfire enough to reach the cutter again. it’s pretty long
The standard torch IPT60 is 18 to 20’ long and the PTM60 is 20’ long. The Crossfire is only a 2’X2" table so you could have your plasma cutter 12 to 15’ away from the table up on a shelf out of the way. You could even put it in another room and run the torch through the wall.
I would love to do that, which is why I’m looking into a ptm-60.
The torch cables that came with my 60s are only 12 foot. A little disappointed at that, but not a huge problem
Well the CNC torch I sell is a full 20 feet long and is not that cheese one everlast sells or those other sellers on ebay and amazon.
