Editing lead in tool path
I am having difficulty in manipulating lead cut in, My issue is this, i cut the cat and mouse from the projects down load. no matter what i set when configuring 2d in CAM , I always get a lead in from inside (the portion i want to keep) , even set lead in to (Off) and tried zero angle , zero radius and zero length. but i always get a lead in cut . how can i move it to other side of cut line or eliminate it all together?
Zoom in click on the arrow .
ok, from which screen ?
In your CAM . When you set up your cut you will get directional arrows for the cutting path. If you zoom in on the arrow it will be inside or outside the cut line . Click on the arrow and it will change direction.
oh, ok…thanks so much
