DIY z axis control
Okay here are the .dxf/.stl files.torch float.dxf (189.9 KB)
motor spacer block.dxf (144.4 KB)
Fixed.dxf (338.0 KB)
floating carriage.dxf (301.5 KB)
Torch Holder.dxf (896.2 KB)
:grin::+1:
Cool. Just need to make them stl extensions & they’re ready to go.
If you need help with the electronics just ask. The write up I did probably would answer 95% of your questions.
Do you find the weight to be a concern when it’s at the distal end of the arm?
I was going to add a linear rail to the far end
I didn’t find it an issue in my setup. I did have to re-level my x axis gantry as there was some deflection but that was expected.
A linear rail parallel to the y axis (I think it would be your x axis now, if I remember correctly) would be nice. I think it would be difficult to get the linear rail and y axis tube not only parallel but coplanar.
Do you happen to have a parts list of what you used such as linear bearings and screws. Already have stepper motor and driver and some limit switches. Thanks
Can anybody download the DXF files, I gust get a error.
Just downloaded all five
once you download you need to change the file extension to stl.
Here is the majority of the parts.
47%20AM46%20AM
Nice. Have you wired it up & gotten it working with the Crossfire control box?
Any update on the functionality of this? I’m considering building one myself, but would love to know it works before I get started!
Thanks for sharing all of the good work.
Same here, would really like to add this if everything worked out.
Have not had a chance to install it yet
Thank you @Kentucky13 I used your design as a starting point for my z axis, then did a lot of reworking on the size mainly to get it to print on my size bed first.
Then I resized the torch holder slide and a couple other things.
But got it all wired up and working tonight, with some help from @Burgs04 write up.
image image image
Any updates on this project???
You liking this z axis so far? Would be great to see an update especially if there were any wear issues.
@TeasleyFamilyCrawler, Have you used the same filament as suggested above? How long have you been running and what results are you getting?
This is what forums should be about!
I used abs to print my axis and it work good.
I Cut two full sheets 2ftx2ft of metal and it was working good. When I redesigned it to make it fit my printer I think I had a little play/ not as sturdy structure to support the torch mount. I did take a lot of material away from the torch holder and also the slides so it even used shorter linear bearings. But I have gone back and did a little more work on my design to ad more structure and the longer bearings again, but before I reprinted it I sold the table.
The only design issue I had with the original design for my table was the clearance for bearings and the bolts on the mount to the gantry it was just alittle off but I just adjust it for my redesign/table.
If I end up getting another table I would print another because it worked good, and didn’t ad that much weight.
The only caution I would tell people before doing a setup like this or any z axis setup, make sure you understand/ or at least have any idea how to setup Mach3 to control the z axis before buying parts to build the z axis.
Has any one installed a Price CNC THC controller on a CrossFire
and install 6 home /limit switches into one input
The 3 remaining inputs for OK,UP DOWN
