I have a buddy that wants me to cut his English wheel body for him. It is 47" x 35"… Will my Pro table cut this?
Thanks for the input.
BTW, I’m running the hand torch… if that matters.
48 x 33.3 sorry won’t fit.
Should I have him make it 46x32? I usually cut signs and brackets for myself and friends. I should not have agreed to do this.
Scale drawing down in Fusion. Scale it to 99% and you’re in business…
Copy, thank you.
yes you can…
cut the 48" side and then ROTATE piece and then move the piece thru so the
cut line at 35" is within the x cutting axis and you will be fine… you can cut it straight
with firecontrol… or make a file with a curvy line and you will be able to cut the 35" side
no problem… make sense? ( you just can’t throw a piece on the machine and cut it… )
Have a great day
Phil
