Cutting between segments
I have a part that has an internal pocket that cuts first and then the torch moves out to cut around the outside of the part. I have tried picking them as 2 different profiles in Fusion 360 and as a single profile selection. Either way, the torch does not go off when moving from the internal profile to the external profile. And the part is cut/ruined? Any ideas what I’m doing wrong?
The only way I have gotten this to work is to post the G code for each profile and run them as separate programs.
Thanks much!
David
Check to make sure your plasma cutter is set to 2T. Sounds exactly like whats happening here. Do a quick search on the forum for more info.
