Cutcontrol "load program" does nothing
When I load any newly-generated gcode (generated from fusion), nothing happens - no machining plan, no errors.
Is there a way to view more verbose logs or something in cutcontrol?
I can load old gcode files with no problem.
I’m using the same postprocessor as I always have, but I have not used my MR1 in a few months and have gone through a few fusion upgrades.
Examining the gcode file doesn’t indicate anything unusual as far as i can tell.
I don’t have an MR1 but something similar appeared with a Crossfire user.
They just downloaded their post processor, imported it to their local post processor library, and files were posted correctly.
Maybe it was on the Fusion side and needed a bit of a “refresh”?
Well, I ended up using a different 3/8 bit tool definition and now it works fine, so there’s something about the old tool definition that’s causing cutcontrol to freak out.
Turns out this was caused by my tool having a weirdly high “number” - it was 9191, if I lower it to something < 20 then everything works fine.
I guess cutcontrol should display an error message or something if it runs into a tool number it deems to be too high.
