I’m changing the feed rate in the tool. I just took a quick look at the different path rules but that is new to me.
I did find a work around with editing the gcode:
In my cutting operation I set the feed rate to 5560 mm/sec. After I run the post processor, I open up the Code editor and manually changed the G1/G2 codes with an F at the end because the feed rate that Sheetcam was outputting was F333600.0 which I just realized is (5560 * 60)… like it is doing a unit conversion. I suppose I can divide my desired feed rate by 60 for my tool and I’ll get the correct output after I post process it.
Maybe I need to change something in the program settings so I don’t have to do the work around?
Good suggestions - the units are in mm/sec. I switched it to another unit, restarted the program and then my feed rate was really wonky. I switched it back to mm/sec and the same issue remains when I look at the code.
OK. If you have it set at mm/sec and you are putting in the mm/min value, it will multiply it by 60, because Firecontrol only uses mm/min or IPM(inches per minute).
If you want to use mm/sec, you need to calculate what that would be. For example, 2000mm/min is 33.3333mm/sec.
If you are using metric, setting the speed units at mm/min. is going to make things easier, as most charts list speed in mm/min.
Yeah - you are so right! I can’t believe I missed this - I just missed the mm/min. My cut chart says right in it mm/min and for some reason I chose mm/sec and then got it stuck in my head that way. Thanks a ton for pointing that out!
I did not - I have been doing prototype work so far. I need to review what my limitations are - the one thing I noticed is a limitation on a number of lines of code which hasn’t been an issue with post processing a design so far. Do you think it is worth buying?
It’s definitely worth buying. The 180 line limit on the code will limit you to small simple parts. A small rectangle plate with 4 oval slots for caster wheels was 167 lines of code.
Yeah - I have been doing simple things like that as well but will definitely be moving into more complicated designs… especially now that it is working properly (: Thanks for all the help here!
