I downloaded a cut ready file, loaded her up as is and when the cut started, it looked like it was traveling 200ipm. Where can I find that info prior to cutting. I see where I am able to change it prior to download but don’t see what it is initially. Thanks
If you got it from fileshare you can adjust it before downloading. If you got it somewhere else you would need to load into your cam software and change it.
Open the file with Notepad and look at the last line of the code. It will be the program speed in this format (PS200)
Kinda of funny but I was using 32 amps and the 200ipm worked great. Never had the speed up that high before. 16Ga. Almost no dross.
I never gave this any thought, your way is much easier!
