When I first started using fusion the cut direction for inside and outside cuts was always was correct but now from some reason they are not and I have to go in and reverse them. Is this a setting that I inadvertently toggled? Its not the end of the world just annoying.
It’s in the 2D profile menu in the geometry tab.
You should be able to find the option there
