I’m having a problem with my primeweld cut 60 it fires and then stops… I have not changed any settings I’m a little puzzled to say the least
Do any of these pervious topics cover your scenario ?
https://forum.langmuirsystems.com/search?q=primeweld%20fire
If not could you elaborate on the details of your situation that makes it unique.
Interference is the top thought
How long have you had it and are you hooked up divided voltage from CNC port or RAW voltage from inside?
A little more info please
Make sure your work clamp is on the clean metal being cut, not the table or slats.
I had same issue with my primeweld. Drove me crazy for at least a week. Worked great for months then out of the blue it would fault out and not cut. After checking wires half dozen times, I finally went inside the cutter and wired it for raw voltage and bypassed the cnc port, and now works fine again. If you are running off the divided voltage on a primeweld, switch it to raw voltage.
