I have a problem with the torch not firing at the start of a program. I am cutting multiple pcs but am manually indexing the sheet as the pcs are 8’ long when complete.
So the first cut works fine and sometimes the second. But normally the second cut wont fire.
It seems to be two ways to correct this but neither one works every time. I can shut everything down and reboot or I can start the program with THC disconnected and then turn on after the torch fires.
I have run the test on THC and everything checks out.
Crossfire Pro, Fire control, Fusion 360, Herocut 55I
Yes once the program stops I reset with THC off sometimes it will fire then. Other times I have to shut the computer and the table down and restart to correct the problem
