is the ESAB HandyPlasma 45i compatibel with crossfire pro? In Europe ESAB is quite prominent.
Or might the Jasic CUT45 with pilot arc be an alternative?
just make sure it is not high frequency start…it will mess up the systems from Langmuir.
https://www.langmuirsystems.com/plasma-cutters
check out the website…they list plasma units that they know are compatible
Keep in mind that manufacturers sometimes use different model names depending on the marketplace/region (the HandyPlasma in Europe could be identical to a PowerCut or something else in the USA).
Thnx. However, I am new to plasmacutting and have ordered a CrossfirePro and would like to order my cutter in Europe. My table is scheduled to arrive in april in the Netherlands.
Could someone look in the specs of the handyplasma 45i and give advice? I think the machine should indeed be fine to work with the crossfire pro table
looked it up…made by ESAB…a lot of the ESAB units are compatible with the table…the only thing I can not see is the arc start …high frequency or blowback…
you want to make sure you have blowback start…the high frequency starts can destroy the electronics on a table…
