@toolboy nice setup and very good organization to have two tanks, compressor and air drier mounted up high and saving lots of room.
          There is an auto drain on the bottom too I just forgot it on the drawing. Thanks!
          That is slick!
          Your compressor is the same as what I have, how long have you had it? Mine had electric motor go bad at 15-20 hours of use, new motor under warranty been problem free now for 5 years.
I have 7 hours on it now, no problems so far. Did it stop running completely or start acting up?
I bought is used last summer…paid $600…had around I would guess 200hrs on it…changed the belt…changed the oil…cleaned the filter…visually checked inside the tank…I have put around another 100 hrs on it…runs fine…
Wat I might do now is get some isolation springs or some good rubber pads to help with the vibration on the wall.
