Is the everlast 52i compatible? Is it bassically the same as the 50s ?
Yes the 52i will work and is the same as the 50S
I see the Everlasting 52i is cnc compatible. Is it plug and play with the Langmuir then or do you still have to splice wires for torch controls?
You still have to hook the wires from the CNC port to the controller.
Is just the 2 wires for torch control on the cnc port?
You should have 2 wires for the trigger and 2 for the THC
