Can plasma produce something similar to this?
Sure, I will upload some pics asap. Consumables haven’t had much use, using a Hypertherm 45XP with book settings. Using figma & sheetcam for svg’s / gcode. I will upload pictures as soon as I can.
Ok hopefully I can look at this sometime next week
I have to apologize, I have a project going that just turned in to a big mess. It might be awhile before I can cut that logo, are you in a time crunch?
Also I did not get the SVG
DM me the file. I’ll cut one, if Knick doesn’t have time.
No problem Knick, thank you for the offer.
ds690, I’ve sent you the file - thanks so much, I really appreciate it!
I couldn’t use the image from the DM, so I grabbed a picture from the Facebook page and did a quick trace in Inkscape.
This could be better if I made the bridges larger in the letters or just made the letters larger. The part is 5" x 1.75".
Here is the result of cutting your SVG file. I still had to bridge the “O” and modify the “G” to leave a large enough bridge. This is about 6" x 2", which is the size that your SVG opened in Inkscape.
That’s great, thank you so much! The bridge makes sense - the originally was definitely too small.
This is pretty similar to the cut quality I’m getting to be honest (using hypertherm with finecut consumables). I’m thinking it’s just a little too small for the lines to be perfectly sharp. I’ve seen jim colt say even he uses laser for smaller items which doesn’t fill me with confidence - back to the drawing board I think :thinking:
If I was going to need more than a few of those, I would definitely have them laser cut. Plasma is just not the tool for the job, if precision is the goal.
Yeah, unfortunately I think you’re right. I’m going to buy a fiber laser machine - it should be here within the next 30 days. I will update when it arrives!
That was really nice for you to try David. Thanks.
What did you buy? I’ve been contemplating a fiber laser myself.
Agree Jim, glad to know I wasn’t going crazy.
I’ve bought a gweike fiber laser James. It’s going to take a month to arrive but very excited to see what it can do.
The engraving series or one of the big ones that can cut? The prices for cutters are just stubbornly expensive :face_with_diagonal_mouth:
Yeah, anything powerful enough to cut 10ga comes up on the $10k mark for just the head and power supply.
The big ones that can cut (it’s 1500W). I think the smaller 100W ones can cut very thin steel but they need a lot of passes. Definitely a lot more expensive than plasma :sob:
