Is there a post processor that will work with aspire? I am having trouble with it not shutting the torch off on different lines, it cut through them. Have tried several post processor. Most won’t start & stop torch, wrong m code. Any advice would be appreciated.
Can you export as DXF or STP files? if so you can use Fusion 360 for PP.
Bob
Export your file as a .svg file. Load the file into sheetcam. Then get your g code from sheetcam. Then cut your file with mach.
I do it every day… works fast, easy, perfect.
Thank you, works good!!!
Great!! Glad you worked it out.
Another option (lot of work) is to find the .pst file that you have been using with wrong codes. COPY IT and paste it into notepad. (should be in a folder called post or post processor, something like that)
Save it 1st before working on it as something else say Fulio.pst
Then you can go through all the lines and change M and G codes as needed, you can even remove stuff that isnt correct for your setup.
Save when done, then copy the Fulio.pst and put it into the folder with other .pst
You can then pick your post processor and Charge forward!
It isnt as bad as you think…well at 1st it is and maybe 2nd to
