I have my crossfire pro assembled and done with all steps prior to connecting my plasma, can I run the break in program without hooking my plasma up and filling the Table ??
I got it …And yes it can be run
Put a piece of material on the table and unplug the torch trigger lead and get to know the table. Load some programs and let them run. Best way to figure it out without cutting anything. Mess with the straight cut feature too.
so it won’t throw me any error codes or shut down if I just load some programs and run them? If I have the torch mounted and some material on table but torch firing lead unhooked?
You can run programs like that with material on the table without issue. You’ll need material due to the initial height sense. Make sure to switch the THC to off so it doesn’t look for arc voltage.
make sure you turn off THC in firecontrol before you start a program or else it’ll thru an error.
Langmuir Systems has a break in program on their download site. I would use that 1st.
