Break In Procedure for Pro
Is there a break-in procedure for the pro? I know the first crossfire has a break in program in the download section.
I asked this the other day with no answer :confused:
It’s not listed anywhere on the downloads or in the doc. I figured I’d create one next weekend after I get my table setup if they haven’t come out with one first. It’s just a non-firing move the head to the extremes & back a dozen times (assuming it’s like the other one). I’d add some THC tests as well. Pretty quick setup with Sheetcam having it “nest” a square with diagonals at max usable size with a dozen copies on top of each other.
After I finish reading the assembly guide maybe I’ll just do one so I can make sure I’ve got the workflow set and then I’ll post it.
Since you have yours running, can you try this TAP file and see if it works? It should run a series of outline & diagonal movements to the extremes (48.5 Y 33.3 X). The initial height should be 0.15" then lower to 0.06" and up to 1" when moving between “cuts”. I’ve left the M3/M5 because I’m not sure that getting rid of them would not also get rid of the THC fast mode (1" rise after a cut) in FireControl. So if you can run it, please run it with the plasma off so you’re not cutting a big chunk of steel :slight_smile:
It should run at 150IPM.
As usual, just delete the .DXF at the end of the file leaving just the .TAP and it should work.
:crossed_fingers:
Crossfire Pro setup test - 5x.tap.dxf (4.4 KB)
