I will look into the control board…
And I will see about performing the mod.
I use Mach3
I really appreciate your help…
I use Mach3
I got the same help from guys here…I am glad there is a forum by Lanmuir for us o help eachother
How tight is your cup on the torch head? I had the same problem before and loosening it a quarter turn or so made it fire regularly. Also make sure the ground is good. I used to clamp it to my water table but now clamp it to the workpiece.
Hand snug
Clamp is on the metal itself…
Okay day after Christmas…
Does anybody know what the voltage
Comming out of the crossfire control box , going into the plasma cutter to fire the torch is supposed to be?
Blockquote How tight is your cup on the torch head? I had the same problem before and loosening it a quarter turn or so made it fire regularly. Also make sure the ground is good. I used to clamp it to my water table but now clamp it to the workpiece.
I even tried loosening the cup 1/4 turn
so here are a couple of pics of my controller board…
new compressor that can keep up
the table works great except I cannot use it to cut…![]()
Thank you everone for your input…
Thanks to everyone that tried to help… the machine has been sent back to Razorweld…
waiting for an answer from them…
UPDATE UPDATE!!!
I would like to thank everyone that gave me ideas on how to fix my Problem.
I had sent the Plasma Cutter back to Razorweld for inspection…
The machine itself checked out okay,but they determined I had a faulty torch…
The Torch has been replaced and the machine sent back now I am cutting like a champ!!!
after a year of practice cuts, I made a bottle opener!!
Thank you everyone!!
