Any way to get these dimensions?
Any way to get these measurements? The measurements from floor to bottom of water tray as well as the measurements in the pictures. Where the machine is going I am going to have to make these points pivot. Figured would be nice to have the mounts made for when the machine gets here. @langmuir-daniel @langmuirsystems
Awesome! That’s exactly what I needed! Thank you! What about the floor to water table bottom measurement. I wanna see if 2-55 gallon drums will fit under it… thanks again!
Depending on the setting of your leveling feet, the distance between the floor and the bottom of the water table is about 32".
Awesome! Thanks so much!
