Having Issues getting the cutter to pierce. It will arch for a couple seconds then loose the arch. The path it traveled wont show any sign of cutting at all. Any Advice?
Material Specs: .25" Aluminum
Cutter: Razorweld 45
Tip: .8mm
Air Preasure: 75 psi
Check work clamp. Sounds like you are not getting a good connection. Sometimes I clamp a visegrip to aluminum and connect work clamp to it.
Setting look good except for your travel speed.
Should be much faster, like 54 ipm or more.
