Hello all. I have multiple cuts that are post processed and ready to cut. Is there a fast way to get all completed g Codes and add it to one file so I can cut out 6 signs in one run? Instead of loading each file individually after each cut?
yes…it is called nesting…but it is easier done in SVG or DFX format…
it also depends on what post processing software you are using
