Probally a simply fix, but this is what I start with. Thanks for the help.
So how far along did you get before you had trouble?I see alot of places that the lines look drawn over itself…Probably alot of nodes in the squiggles on the bottom as well.Ive had things I let set overnight that wouldn’t generate…had to simplify the drawings.Highlight your drawing and right then choose fix/Unfix and it will show you your nodes and potentially why it wont generate.May have to redraw the areas with alot of nodes to get it to generate.You need a defined line around the parameter…no places that the nodes just make a cluster.
