ok so I have never done anything with layers, and this is as far as I have got.
So the M is one layer and the bottom the 2nd. I will put something on the backside of bottom layer to glue the pieces of the lettering that will fall out.
So I am stuck as to how I create the holes through both layers? My work flow on this was probably all wrong but I did not find much on the very basics of layering. If you can point me at some videos that maybe show the workflow and putting holes through both layers would be great. Don’t spend a lot of time trying to expalin on here as I really need to see it being done.
add your holes on top layer and copy and paste and remove the things you don’t want on each of the layers. Heading to work but hopefully this helps. i did this drawing for a different reason but concept is the same.
