So i’ve sketched up a design for a customer and im trying to send them a drawing view of it. when i load up my sketch into the drawing function of fusion360 the lines are all broken up and its hard to make out my design. Am i missing a simple button to change it back to solid lines?
You need to go into your sketch and change your lines from Construction to normal. Looks like you drew the whole project with the construction line toggle on (easy to do).
Select all the lines then Click on the blue highlighted wedge to turn Construstion off.
Sketches in drawings will be shown as dashed lines. If you extrude the parts and build an actual 3d model of the design the lines in the drawings will show up as solid lines.
Here is just a sketch and how it shows up in the drawing:
