Torch Relay tech specs
What are the technical specs on the relay that turns the torch on and off?
I’m wanting to turn on and off a laser diode and need to know if it can handle 12v and 4 amps.
I have a picture posted of the (reed) relay. Don’t recall the exact specs but from what I remember it can only handle a small amount. Maybe less then 1 amp @ 12v.
I’d like to set up an E-stop on my table as well, can you post a schematic or wiring diagram of that?
