Razorweld 30 trying to cut out the punisher skull out of 14 guage steel.
Machine completes the cut out of the eye and moves onto the nose, completing it as well, then fells to fire to cut the rest of the tool path as it continues going over the complete path with out cutting.
.5 pierce delay
Razorweld 30 wired for 220 volt
large compressor capable of 18 cfm at 90
multiple dryers and, air is clean.
Unfortunately the 45 doesn’t have that resistor so there wasn’t a fix for my Machine, then the torch just quit working. RW is sending me a new torch but I went with another plasma cutter and will be selling the RW unit.
I just got my table set up and did all of the proper mods to my vipercut 30, including removing the capacitor. I am still having issues with the air not turning off between cuts. The first cut does well, the second misses, the third does well and so on. It seems the vp30 turns off the air after some cuts but not all cuts… I did try using the vp30 before removing the capacitor and the first cut would do well and then nothing after that as the air would continue to be on throughout the rest of the program, so it seems removing the capacitor has helped somewhat but not totally solved the issue. Any thoughts? Thanks in advance!
So is this capacitor on the underside? do you have a better description of where I can find this capacitor? I’ve look and really not sure where to start.
