Tell me what I’m doing wrong here
Not sure why tabs are connected there or why my cuts are lapping
If i had to guess, your pierce delay is too short.
Also the squiggly cut outs are too close together to have a ‘bridge’ between them.
Would pierce delay cause the little uncut tabs? And can I determine if the machine cures inside or outside of the squiggles? Or is that computed automatically?
I dont see a lead-in or lead-out cut and i personally prefer to use them. Makes all my cut edges come out perfect. I agree with Daniel, too close together too
I’ll try that when I get some time this evening. Very new to this cnc thing…
Hope this isn’t asking to much, but what tab can I use lead in/out on?
This is 16ga by the way
Too short of pierce
Too fast of cut
or torch is too high
I ended up staring from scratch and got things ironed out, could maybe use some tweaking on feedrates and amperage…
Is this picture the bottom or top of the piece?
That is of the topside
Looks better but I think you can improve the cut even more. What are you setting? Amps? Ipm? Tips size? Standoff? Pierce delay?
It’s 16ga, at 35amps, I believe 40ipm, .9 tip, 1/16” stand off and a 1 second pierce delay, with a lead in of .065”
this is where I screwed up I should have went with the 45 amp machine I went with the 30 but I would say yes your pierced delay needs to be turned up on a 16 gauge I use a pierce delay of . 4 at the full 30 amps
Have you done a line test? At 35 amps I’m thinking you should be in the 70-90 ipm range.
FYI there also is a setting below your lead in/lead out called “Pierce Clearance”. This distance is added to your lead in distance. I always change this to 0 if I’m using a lead in. You can cut a smaller design playing with this setting.
I’ll reset and try it again, at 40, I’m getting some spray from the top, I thought it meant I was moving to quickly, I’ll give 70-90 a shot
Top dross could also be from consumable wear and too much of a standoff/cutting height. Essentially the metal that’s coming out on top should be going through the bottom.
Well didn’t get to try 16ga tonight but did some 1/4” used the small shim, machine set at 40 amps with .9 tips with a speed of 30ipm. Will post some pics in a bit, but does that sound right?
Doesn’t sound too bad. You have your tip maxed out though. Might try 35 amps and 25 ipm
I’ll give it a shot next time, and a question about shims, I had better results with the smaller shin on 1/4”, do you use the bigger shin for thinner materials?
No. Thin shim thin marterial. Thick shim thick material. Thick shim is for 1/2 an above
