SVG Importing & extruding
Why would my .SVG extrude out (embossed) instead of through the part? Can’t figure out why this keeps happening. Not all the time either. Some are fine think I am doing them all the same from what I can tell…
So is the inside parts exstruding too?Like the things you want ty to cut out?If thats the case you have broken lines.You can down load sketch checker from the autodesk app store to find broken lines.Keep in mind it does some times crash so save your work before you use it.The app store can be accessed through a drop down box on the top tool bar while in fusion.
