Skull and crossbones that is preloaded on mach3
I was going to cut one out. It takes up more than the table has. Is there a way to resize it to say 12ish by 12ish? Thanks , Jim
Adjust the scale to fit. 0.5 will equate to 50% of the original size. Make sure you update both “X” and “Y” with the same value.
Thank you, Without you experienced guys the rest of us would not be able to do much. Pretty simple once you pointed it out! Thanks ,Jim
