Does anyone find an advantage to using shielded consumables for cnc cutting? with a standard hand torch.
I used them for years on mine, better than the drag for sure.
CNC shielded consumables are the way to go even on a hand torch. But depending on the torch you may not be able to get shielded consumables.
I am planning on going with the primeweld cut60 / ipt 60 torch - and I will be getting the high-quality consumables from you… Looks like you carry all the shielded consumables for this torch.
