So in the CAM section when I want to make toolpaths can I make multiple setups on the same geometry? For example if I want to cut only a portion then a diferent portion on the same part make 2 set ups then make 2 new tap files, one from each set up?
So I could approach one sheet with 2 or even more programs and have diferent settings for each one?
Also how do you make a piece point? So just burn the hole then move on?
Can I just make a mark without going all the way through to drill out later?
