Sometimes i have to reverse the entire toolpath…is there a quick way to do that without selecting every arrow.Does it matter how you select the feature to determine if its a inside or outside cut?
Extrude the part in model. Then in cam select the face you want to cut. Fusion will automatically select the right direction for all cuts.
