Does anyone know where I can get the cut chart for this? The only one I found on the forum is for the razorweld 45. Any help would be much appreciated I’m going to be cutting 11 gauge steel with the razorweld viper 30 And I need to know the cut speed for setting it up to generate tool path and cut simulation
You should be able to use any of the settings for 30A or lower on the 45 chart.
I thought someone was thinking of starting a dedicated 30 sheet but don’t know if they ever did.
