Razorweld cut charts
Thats a good 3/16 cut
Thanks man. Iā€™m still having trouble with the plasma arc going out randomly though, but I do notice water in my line still. So now Iā€™m working on a dryer setup
You went to the 1mm tips right? Where did you find them?
@freeman yes I did. I ordered them thru eBay. Unfortunately they are the ā€œdrag styleā€ so the .060 tip to part distance is already accounted for in the nozzle tip. So I just eyeball the tip as close to the material as possible, dry run the program to make sure it doesnā€™t hit the material, then do my full run. I really like these tips though. I have cut a bit of 1/4ā€ and 1/8ā€ aluminum with no bevel issues. I recommend them for sure. I just switch back to the .8mm tips when doing thinner material that doesnā€™t require the high amperage.
Why not let it touch the material? Thatā€™s why they have those nubs.
Because it would move the materialā€¦ they are more for hand cutting not cnc
I usually clamp the material down - maybe not needed but itā€™s a habit from dealing with warped materials in lasers and CNC routers require it.
Do you have a pic of how you clamp material? Iā€™ve been trying to figure out how
I usually use rare earth magnets or large C-clamps. But Langmuir suggested using a 3ft metal bar across the edge of the material and clamped to the frame of the Crossfire that Iā€™m going to try.
Iā€™ve extracted all the posts I could find here with settings noted for the Razorweld machines. (Only a half-dozen though :slightly_frowning_face:)
Iā€™ve put them into a Google Sheet (spreadsheet) and will share it. Iā€™m setting up another thread to help keep track of settings and peopleā€™s comments. If people either post the info or update the sheet we should end up with a nice reference.
Awesome James!!! That would be great. I will be cutting some 3/16 mild steel here in a few days so once I try some settings, I will post those as well
Thanks. Yours are 2/3 of the entries Iā€™ve found so far :slightly_smiling_face:
The link to the new thread is in my post above.
just got my machine running with the razorweld 45. had the same exact issue. changed out two different sets of consumables before one combo would work good. I just cut 1/4" at 45 amps and 20ipm. did well. as soon as i can find some better higher amperage consumables i will see if i can make some adjustments.
Are you using a 1mm nozzle?
no. im just using the standard .8 the 1.0 are on order now.
Ya the .8 is going to blow out quick running at 45 amps. I wouldnā€™t use the .8 anything over 35 amps
Yeah - Iā€™ve been using no more than 30A until my 1.0s came in (today). Need to go slower but the tips last longer.
Looking to see if there are any .6s out there - for really thin kerfs in light metal.
Do you check your nozzles with a jewelerā€™s loupe for out of round?
completely agree. thats why i have 1.0 tips on order
Nah, I just periodically check the opening and if it looks out of round, I just swap it and the electrode out.
:slightly_smiling_face: the Hypertherm guys are OCD about how we should check them every time we use the torch and recommend using a loupe to see the changes better.
Iā€™m not quite as disciplined about that - I look when I remember - not every time but often.
