Oil catch can made on the x fire
Here is a oil catch can I make for mk4 Toyota Supra’s. They are double baffled, 1/8” npt drain, 1 1/2” filter and -10 inlets. I designed it in fusion, cut with the razorweld 45, and welded with a everlast 200. And yes, afterwards I did nest the program so I wouldn’t have so much waist lol.
Nicely done! How did you complete the logo etching?
Nice work. Definitely can tighten up the nesting - it hurts to see all that steel going to waste :grin:
Awww tricked ya :wink: it’s not etching. It’s just a decal made out of this “etched glass transparent vinyl” the etch look is what I was going for
Ohhh I know. A learning experience for sure
Still nice. Maybe do a negative of the decal and really use it as a template for an etch? Nice welds too, btw.
Really cool, Andy- we’d like to share these pics on social media if you don’t mind.
Not at all, have at it Daniel.
Very nice! How was the welding after plasma cutting? What kind of prep did you do?
Welding was just fine man. I sanded the pieces with a D.A. Using 400 grit then a blue 3m 3” buffing pad on the edges, wipe with acetone and weld away
Glad to hear, thanks for the tips!
That looks awesome! How thick is the aluminum on one of those?
Thanks man, I use 1/8” on these. Welded at 125 amps
