I am trying to generate a cut path for a hexagon art piece inside a frame. The problem I am having is the lead ins are generating in the frame. I have tried to select the inside of the art, but it will not recognize the shapes on the edge because it is attached to a non cut line. I believe I am explaining this correctly. Please Advise
Also, one of my hexagons was completely skipped.
I think this will need pics if not copies of your project
I am to new to the forum I can’t post pictures yet. Thank you for your response
Try re-doing the cutpaths in Fusion, inner cuts should go counter clockwise, outer paths clockwise–you can simulate the cut path and watch which way the tip is moving to ensure all things are going in the right direction. I had this wrong on something I was cutting and all the lead ins were on the sections I wanted to keep vs discard (cutouts) Pictures would help too
