Pickup table tuesday - assembled and tested with a new 65 amp. Tested on thin aluminium and … the complete setup is marvelous!!! Thickness is .032 inch. 30 amp, Hypertherm Finecut, 150 inch minute, .7mm kerf. 20190405_184140|243x500
What consumable setup did you use on the Hypertherm 65 for this? I have the same plasma works great on steel but aluminum has been less than Desireable.
What shield did you use on the finecut?
I used the 854 retaining cap, 930 nozzle, 931 shield, 842 electrode, 947 swirl ring ; automatic air control.
Never tried using the 931 hand shield I’ve only tried the 948 machine shield. Might give that a try. Thanks
