Hi, im having a constant issue in Fusion 360 where i can’t get rid of the system wanting to cut(green line) before the actual line i want cut, almost like a lead in that i cant get rid of. I can change it to a straight lead in but then it ads to the length of the cut, but the inside cuts it is giving me linking constraint issues cause the space it wants for those. Any help would be appreciated!
In the lead in tab there is also a “pierce clearance”
Change it’s value to zero.
Awesome, thank you!! I seen that and for some reason was thinking that was the kirf width… But thank you again for the help.
