So I am having this incomplete cut on the first pierce of every file I load up into mach3. Has anyone else run into this problem? I recently upgraded to the everlast 50s and this is when the problem started occuring. I searched around the forum but I didn’t find an answer. Thanks in advance.
I’ve noticed with my 50s that the first torch fire lags a bit. I might try to change the pierce delay in the g code for the first cut and see if that helps. Or just add some time to your delay in fusion.
If you change the pierce delay in the g code. Open your file with notepad and find the first pierce delay. This will be the something like
N20. M3 P0.4
The numbers after P is your pierce delay. Might change the first delay to 1.5-2 seconds and see if that helps.
I have just been editing my gcode like @burgs04 said, after post processing it to give the initial pierce a longer delay, it works fine just adds and extra step.
I have also fired the torch prior to running the program, get it all setup zero it out then job out of the way a bit, fire torch then return to zero and run the program… its haxing but it works too
