Anyone have a cut chart started or a good reference chart ? Im new to the cnc plasma and looking for some tips
thanks
Mike
thanks
Mike
I do not have an everlast machine but have been looking at getting the 80 amp machine. I contacted everlast with the same question. They told me to use the hypertherm 85 cut chart and reduce by 30%. Hope this helps.
Thats interesting…I was looking at those. If their machine is truly capable of 80 amps then why reduce 30% from a 85 amp machine. 85 amps - 30% = 59.5 amps
If you look at the machine specs the hypertherm runs at a higher voltage. Amps x volts = wattage which is total output.
I was comparing the 80 amp everlast with the hypertherm 65 the specs are similar.
