Finally got some time to do a comparison between the Everlast 50s and razorweld 45. I’m going to try not to be bias as possible and just lay out the facts of both machines. So first I will start with price. Prices were pulled from amazon.
Everlast 50s is $730
Razorweld $850
Everlast is a 50 amp machine
Razorweld is a 45 amp machine
The Everlast has an external cnc port. The machine comes with the cnc plug, you simply cut the spade connectors on the wire provided by Langmuir and solder them on to 2 pins of the plug.
The Razorweld requires you to remove the cover, tap into 2 wires, then run the wires to where that are hanging out of the cover to the Langmuir control box.
Everlast has an adjustable regulator and a large easy to read gauge right on the front of the machine.
Razorweld, the regulator is behind the cover so you do have to remove the cover to access it, but the gauge is also on the front of the machine.
Both machines have water separators
Both machines have buttons to check air pressure when the torch is running.
Everlast has a digital amperage readout on the front of the machine.
Razorweld has a knob that you rotate to the desired amperage.
Everlast tips have a fairly easy to read size on them, which makes identifying tips very helpful, especially if you have a variety of sizes.
Razorweld tips do not have any sizes listed on their tips.
Both machines do not come with recommend cut charts.
Everlast has an adjustable strap to carry it.
Razorweld has a handle to carry it, and the Razorweld is lighter then the everlast.
Everlast comes with 6 tips and electrodes, all 1.1mm.
Razorweld comes with 2 tips and electrodes which are .8mm
I think this pretty much sums up both machines, as much as I can recall anyways. If anyone has any questions, don’t hesitate to ask. Hahahahaha
