Error when creating toolpath
They turned out great.
I usually create multiple toolpaths. I alter the lead-in/out parameters for each one so I get better control over part cutout. I usually start with an outline cut (last one to do) and then an inside cut path for all of the larger inside parts and my initial last one is the small (ones I know won’t work well with my standard lead-in settings) parts.
If I need to I’ll make another one for even smaller parts or plain line cuts that might need me to skip the lead-in altogether.
Then I order the toolpaths in reverse of the above order. That way the little stuff gets done first and the outline cutout gets done last.
