Connect The Dots Add In for Fusion 360
Thought Ide throw this out there for people that are having issues with their dxf files not extruding due to lines not being connected. This add in will save you hours on files that have a lot of issues with lines not being connected. I just fixed a file in a matter of minutes that had probably 50+ broken lines.
What add-in?
Do you have a source?
download and add into script under the ADD Ins on tool bar.
Just download Zip open file folder, extract, right click copy, open up fusion , click add ins, select + next to script, and paste folder.
Makes fixing files so much easier than trying to find all the broken lines, but you may have to select whole drawing multiple times if there is a lot of detail and a lot of disconnected lines but it will connect them to their closest point
Every time I try running the script it crashes Auto fusion, any tips?
If you don’t have luck with the above app try this one.
You’ll have to manually connect the dots though.
How do I find add ins? I don’t see it on my toolbar. I added the files in a folder in scripts and got nothing when I opened confusion 360
