Want to make tabs and brackets to weld up. Can u cut titanium on plasma? I know it reacts if it gets too hot. Green cut says it’s compatible with titanium. Any1 have any experience?
Should cut fine, you will need to clean up the edges before welding though.
It will leave a nasty edge, worse than a stainless
Also it has BRIGHT white sparks and smokes a lot
Be careful.
