Originally had a simple 1" wide metal strap going across to hold the battery into the tray…that was pre-LS cnc though, and it was boring… granted it will probably never be seen (battery is in the back, only time you’d see it is to change or disconnect it)
Looks good. Just getting up and running but have realized already that when drawing up something I am making it a lot fancier or more intricate than if I was cutting out by hand
Looks great, good job!
I don’t have my machine yet, but when you draw up an item to be cut and then broke. Do you have to draw in extra room for the brake? not sure if that makes sense
in f360 you use the sheetmetal work bench and you create a flat patern from your folded model. it will automatically add the bend curve
What about the thickness of the actual cut?
not sure i’m understanding your question
