2D DXF File COPY PASTE in Fusion360 & Copy Paste Cut Paths
Think this is it.
Was an issue about multiple geometries and normal / ROBO dxf file formats .
FUSION does perfectly fine with a svg file also
As long as you stop your sketch and then extrude it. The
CAM / MANUFACTURE setups are a breeze. After that.
I’ve not had an issue with any file I import from INKSCSPE Since. Wether svg, dxf, of dxf ROBO Master format
